Multisectional electric heater PLC vernier control
val_99
Mar 2005
138
Hi guys.
I'm working on a logic to control multistage electric heater for an air stream. The heater consist of 10 sections with ON/OFF control and 2 sections with independent proportional control.
I have to write PLC program emulating vernier control.
My first approach was just simply split 100% PID loop output range on 12 and turn ON/OFF discrete sections any time 8% step is made. Rest 2 proportional sections can be controlled in parallel between 8% steps, modulating its output from 0 to 100 within 8% step and resets to 0 after new step made.
My concern is that output temperature will be bumpy due to difference between newly "ON" heater section warming and just turned off "proportional" section cooling.
Just curious if anyone has better ideas for control algorithm or maybe a references/links to useful materials.
let the two proportional do their job and control them.
the switchable just switch on when temp lower then proportional band
do this with a time delay
Rs485 module then 2 wire belden 9841, modbus network picking up electric meters. Does this need to be wired as a ring or a radial? Thankyou
98
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
247
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
252
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
815
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
124
