PLC logic
patelaksh30
Mar 2018
USA
Hello Everyone,
Can anyone please help me to accomplish this issue in Rslogix.
Input- 1 Momentary push button
Output - 1 light
1) When we press push-button light comes on and we took off a finger from a push button and light stays on.
2) When we again press that same push button, the light goes off and when we take off a finger from a push button it stays off.
3) Again when we press a push button, the light comes on and when we take off a finger, a light goes off.
you can use any instructions.
Regards,
patelaksh30
If knowing how to do that is part of a job requirement and you can't answer the question either they need to understand that you need more education or the job isn't for you (no offence).
Code:
If s:1/15 then
  counter:=0;
end_if
If (plc_type = slc) and s:1/15 then
  Input1.en:= false;
end_if; (*now i'm just getting ****y*)
If RE Input1 and (counter < 2) Then
  Output1:= Not Output1;
  inc(counter);
End_if;
If (counter >= 2) then
  Output1:= Input1;
end_if;
(*some jobs you may not necessarily want.*)
I'd hire you just on your ability to say "I don't know".
You'd be surprised, that is a hard commodity to find.
I don't understand are u supposed to pick a number if so I pick 3 I am just confused with them ?.
it is a sequence
also one of solutions for mitsu :D
yCMubcV
it is a sequence
yCMubcV
sczot, what is the value of the reset for the counter ?
patelaksh30, 1 and 2 are just a normal flip flop but you need to get a little creative with 3 so try using a counter and the equal of the counter
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
837
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
202
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
247
Hello, I have problem i'm working on boiler plc, but i get to the problem that i can't solve myself. I have problem with material gate. I need to...
356
Hey, I am entirely new to PLC's and am trying to help my friend with a project. He wants to take the signal from a PNP photoelectric sensor as...
2,239
