Plc problem
RICARDOD
Feb 2014
Elmendorf
Computer not sending signal to output
Module output module not sending signal to
Inter posing relay please help don't now why
This is happening
Is the output turning on?
Can you detect a voltage at the output card when the output is turned on?
Is there a supply for the output card, and is this present?
It's module 14 on digital screen I should see
# 11 on meaning inside of module contact 23
Should come on when 11 is on screen I'm not getting
11 to come on and 23 is not sending 120v to
Inter posing relay
I am not getting fault alarms I got cambelt#1
And bucket elevator working in auto and transfer convayor
Should be working but it's not that's the problem
It might be helpful if you could tell the forum what PLC you have, modules, catalog numbers? Maybe even post the program, zip it first.
And tell us which output is not working.
Is the routine that controls this output being called?
RICARDOD
"Help" is not going to be provided if you can't provide what has been asked for..
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
116
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
16
575
Good day, I have an issue between an M340 PLC and a PRA 0100. The problem is as follows: I have a communication link between the PLC and the PRA...
839
Hi, I have a Mitsubishi FX5U PLC where I cannot established communication via ethernet port of my computer. Search all videos and follow all the...
1,331
This is the problem, I need to solve it using a ladder diagram: Write a table of inputs and outputs and propose a control solution for a screw...
22
4,071
