PLC uploading problem
angi
Jan 2010
us
361
Hi guys
I got a problem when I tried to upload the code form Micrologix 1000 to my laptop, there are no any description for the code, the code itself is ok, how come the description disappeared?
I support mordres answer the only plc that I know of that hold the descriptors is the new line product of PLC from automation direct.
The Compact and Control Logix series controllers store descriptions as well as code.
The older SLC family does not.
You will need the source files in order to get the documentation.
can you upload the program, then type in the descriptions of the instructions, then save this code (with descriptions). I guess this is assuming you have an electrical schematic to follow.
Wrong !! - CompactLogix and ControlLogix processors do not store descriptions.
The only description stored in a Logix processor is the Controller description from the Controller Properties dialog.
They do store "Tag Names"
Yes - then next time you go online with your new project file the descriptions will annotate the code.
I assume you do not have the original source file, as provided by the program author ???
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,461
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
190
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
707
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,105
On my laptop I have an old.acd file with important comments in it. The file was modified and downloaded to my AB-1756 long time ago. Later a few...
2,012
