PLC with LCD problems :(((
mark009
Jul 2012
KL
hi every one , i am doing my FYP and I use plc to control
i have many problems o_Oo_Oo_Oo_Oo_O
let me explain the project
water tank with ultrasonic, as the water decrease in the tank the water flow out should decreases too (I'll use flow control valve to do that)
I want to show the info. on LCD screen (water flow rate, the water level on the tank, is the water increase or decrease?)
the problems are
1) how to make the PLC know if the water level increase or decreases?
2) how to show the info. on LCD ?
3) how to send the wanted output signal to the valve?
If you know any references please send it to me
thanks
hi every one , i am doing my FYP and I use plc to control i have many problems :banghead::banghead::banghead::banghead::banghead: let me...
20
4,656
As part of my self teaching journey I want to build a better trainer. I will be using an analogue CLICK as the CPU with a few switches and lights...
3,612
any body can help me how to communicate LCD tv With allen bradly PLC. LCd will Act As HMI.
5,648
Need some help/advice, I am trying to use an HMI possible with a TV-out (VGA) option, so I can push some manually fed data from the HMI to a Large...
3,199
Is there any method to connect an LCD to a PLC .... if yes, please give me an image clarifying that.
5,308
