PLEASE help me with some terms and abbreviations
Atashkent
Mar 2009
Tashkent
I would appreciate if anyone could help with eng to eng (or eng to rus) explanation!
or post a link to a doc i could refer to for expl.
I'm currently working on tech doc (eng to rus) related to replacing old PLCs with ControlLogix ones. I have problem understading some of the terms and abbr.
i know it's an imposition but i'll be very thankful if you can open some of them.
1. For PLC Object
PV
DB
HHSP
HiSP
HiALM
HHLAM
Debounce
Override En
Override Dis
________________________________
2. Under Input&Outpu Processing
Run Status
RUN IND
Permissive/Interlock
3.
Point configuration
point declaration
icon point linking detail
popup poing linking detail
FB pin point name
parameter PV/OP/MD/Source
Under FB pin point name - abbr. IND
______________________________________________
4. Foam Header Permissive (context: If any of three open commands i.e. from HMI, logic or field is generated, the valve will open regardless of the close commands. However, for closing all commands should demand close to close the valve. However open command will work only if the Foam Header Permissive is normal.)
5. Deluge Pump:
Fail to SD
Fail to BD
6. Duty/Standby motor
Scripts on DSBStatus will run on Load and Update events?
7. Animation details
Under Status description: Trip (fill color animation Red)
______________________________________________________
8.
ESD Analog Inputs for HIPPS
Input&Output Processing for HIPPS:
Process input
Input Scaling
Control Set-point
Control Output
_______________________________________________________
9. Alarm Management
Inhibit/override expiry alarm
Alarm inhibit/override
Deviation alarm
Fault alarm
HH/H/LL/L Alarm
Device alarm
Device Inhibit/Override alarm
First Out
Translating (properly) technical terminology is always scary business.
Since you seem to know English but are not apparently proficient in controls-related terms, do you think it might be a better idea if people around here just try to explain the meaning of some of these words and abbreviations - still in English - and leave it up to you to find the best equivalent in Russian?
Here are the abbreviations and specific terms.
For the rest use dictionaries :)
PV= Present Value= Текущее значение
DB= Database= База данных
SP= Set Point= Установочное значение (например, настройка порога срабатывания)
ALM= Alarm= Сигнал тревоги, авариийное извещение
Override= Обход условий (например, возможность работы машины с открытым ограждением)
En= Enable (Разрешить) or Enabled (Разрешено)
Dis= Disable (Запретить) or Disabled (Запрещено)
ESD= Emergency Shutdown System= Система аварийного (экстренного) отключения
ESD= ElectroStatic Discharge= Электростатический разряд
HIPPS= High Integrity Pressure Protection System= Изощренная система управления, ставящая целью предотвращение превышения давления, в отличие от систем защиты путем сброса избыточного давления.
Duty= Работа, активное состояние устройства
Standby= Ожидание в состоянии готовности к работе
Inhibit= Обездвиживать
Interlock= Связь между устройствами (механическая, электрическая, программная и т.д., запрещающая недопустимые сочетания их состояний или действий).
Trip= Выключение в результате срабатывания защиты (хорошо передается русским "выбило")
That's exactly what i need (english to english explanation). That would be great!
Either "process value" or "process variable", if there's any difference.
Most likely, I think. Something that is being controlled, acted upon - temperature, pressure, position... whatever. Регулируемая/управляемая/контролируемая величина/параметр.
Inetrlock or Permissive - whatever set of conditions required to turn something on/let something run. Блокировка.
Debounce - I don't think there is a single-word Russian term for that. In my old days we used to call it "антидребезг", but that is rather a slang than a proper term. The idea is that some electrical devices, like contacts of a switch, when closed, do not make a solid contact right away but 'chatter' for a short time, which may cause a control system (a PLC) to react incorrectly.
There is a set of standard measures that filter that chattering out, they are called 'debouncing'. See if something like "защита от дребезга" or "фильтр дребезга" may work for you.
HH (High, high), H(High), L(Low) and LL (Low, low) are different categories of alarms caused by a PV (process variable, that is) going, accordingly, way too high, just too high, just too low or way too low.
Как вы считаете, корректно использовать следующие эквиваленты:
Duty/standby motor = рабочий/резервный мотор (двигатель/привод)
Interlock = блокиратор или взаимный блокиратор
Trip = размыкатель, расцепитель, автомат. выключатель, или автостоп?!
Override En = разрешена/включена ручная коррекция (блокировка автоматики)
Override Dis = запрещена/отключена блокировка автоматики
Duty/standby motor = рабочий/резервный мотор (двигатель/привод)- Да
Interlock = блокиратор или взаимный блокиратор- Да, но с разъяснениями.
Trip = размыкатель, расцепитель, автомат. выключатель, или автостоп?!- Нет. Trip- это не устройство, а состояние или (даже точнее) приводящий к нему процесс срабатывания защиты.
Да, если не возникнет путанницы между состоянием (разрешено) и командой (разрешить).
И я бы перевел как "обход".
Антидребезг- вполне официальный технический термин (не сленг).
Но я не уверен, что здесь это имеется в виду под debounce.
Блокировка- хороший перевод. Мне в голову не пришло.
possibly . . .
3. FB pin point name
(what I call a 'tag'). Brownish boxes are FB (Function blocks).
Not Controllogix brand, however.
9. Alarm Management (generic, not Controllogix specific)
some alarm expires, there's a means to stop the expiration of the alarm
some means of override the alarm and its effects
Deviation alarm
generally a ± threshold value on either side of a nominal setpoint (SP). For instance, alarm SP is 100, deviation alarm of ±5 would have a low alarm at 95, a high alarm at 105.
Fault alarm
Fault is an internal problem in the CPU processor, its backplane, its I/O modules, frequently communications faults, too.
HH/H/LL/L Alarm
HH = high-high example 110
H = high example 105
LL = low low example 95
L = low example 90
Device alarm
First Out - a determination made when multiple alarms occur, which occurred first.
"фильтр дребезга" works quite well!!!
В тексте встречается термин "debounce timer" for which I used "противодребезговый таймер" (though it sounds awkward). Поэтому здесь, скорее всего, именно ввиду именно антидребезг (таймер фильтра дребезга).
Well, looks like something begins to work out :)
Look at danw's post above - he does not speak any Russian but gave a pretty good explanation for some of the terms.
please help me . I have to make this ladder diagram and I can’t figure it out :(
342
Hello, I am trying to get a Yokogawa Hart pressure Transmitter and a Rosemount Temp Transmitter to read on a 1769-IF4 module on an L33ERM...
378
Please help me, I have solve many week but still not solve it. I found trouble of factory talk studio when I set tag by browse address of OPC...
121
Hello Everyone, i Have im my Industry a Endress & Hauser Promag400 this has a screen that constantly have that error, it says to wait, somebody...
485
