Pneumatic 4/2 and 5/3 valves ??
userxyz
May 2002
any
2,768
I'm not sure if valve is the right name in english,
If u have a double working cilinder, the you cannot use 3/2 and need 4/2 valve, or 5/3.
When do u use 4/2 and when 5/3 ?
Is 5/3 good for emergency stops ? I mean, when their is such a stop, the compressed air is cut and u don't want to have a motion anywhere ?
And 4/2 for general applictaions then ...
Just for updating my pneumatic knowledge
For such an application, it is not enough to cut the supply air. Be sure that the air on the output side is vented in the inactive (middle position).
...unless such an action will increase the level of the hazard. Your hazard assessment should be able to tell you that. I have had cases in the past where an all ports blocked center position was deemed a safer option than center exhaust.
But, then again, (for those of you in the US) I am finding I am NOT smarter than a 5th grader. So take my responses for what they are worth.
Keith
I have an actuator operating a clamp that requires PLd/SIL3, I’ve seen some SMC double valves with feedback, but they are described as dump...
2,364
So how do you go about controlling the open center or open center valves? To get to that closed or open part, I assume you need to have both...
21
4,199
What are the differences among solenoid valve, solenoid air pilot valve and air pilot valve? I read a powerpoint slide from a website (Please see...
1,379
It has come to my attention that the old PLC-2 system was Tric outputs so it did not matter. We have a Micrologix 1400 PLC with add on I/O modules...
28
8,600
Any thoughts on this one? I'm designing the controls for an operator-loaded, light-guard protected hydro-pneumatic press (pneum approach...
4,393
