Pneumatic Valves - Open Center/Closed center??
If after venting compressed air energy, there is a risk of movement or dropping because the pneumatic energy isnt holding things in place, there must be manually inserted safety pins or jigs, or automatically actuating clamps/brakes integrated into the cylinder.
However, for the integrated clamps I have seen that such clamps are not accepted in certain industries, but I dont know the exact reasoning.
Thanks for the feedback.
I guess where I was confused, was if I remove the air via an air dump, the potential for harm is still there if something were to fall or move. So I wasn't sure if by dumping the air, did I also need to assure the valves were locked in place with the same regard. I guess the simple answer is "of course".
Thanks for the clarification.
I see some of you are concerned about dumping the air on both sides of the cylinder
An option would be to revere the action of the solenoids energize to vent pressure o both sides with solenoids off. this would give you the results you are looking for.
I have an application like this that vents both sides for ZES but like Seth350 points out once the device is enabled it will slam back into position. The OEM requires you to push back by hand if out of home position before energizing to prevent this. Thoe no operators do and it takes quite a beating.
True, Ford and GM are now telling us that rod-locks are no longer considered adequate for safe stopping; citing rod-lock wear as one reason. If the cylinder is actuating a slide, a safety rated slide clamp is required. And without some kind of safe clamping to inhibit motion, the mechanical designer has to go back to the drawing board.
I have an actuator operating a clamp that requires PLd/SIL3, I’ve seen some SMC double valves with feedback, but they are described as dump...
2,364
What are the differences among solenoid valve, solenoid air pilot valve and air pilot valve? I read a powerpoint slide from a website (Please see...
1,377
It has come to my attention that the old PLC-2 system was Tric outputs so it did not matter. We have a Micrologix 1400 PLC with add on I/O modules...
28
8,600
I'm not sure if valve is the right name in english, If u have a double working cilinder, the you cannot use 3/2 and need 4/2 valve, or 5/3...
2,379
Any thoughts on this one? I'm designing the controls for an operator-loaded, light-guard protected hydro-pneumatic press (pneum approach...
4,393
