What are the differences among these pneumatic valves?
zmarcoz
Jun 2011
US
What are the differences among solenoid valve, solenoid air pilot valve and air pilot valve?
I read a powerpoint slide from a website (Please see attached picture). I believe I know what is solenoid valve, but what are solenoid air pilot valve and air pilot valve?
Please help
"Air pilot" has two hoses pushing on the pilot valve which in turn "relays" air flow to the main spool or poppet valve. So instead of wires coming from this spool valve, you have air lines. The control of the air can be anything but is external to the spool valve.
"Solenoid operated air piloted" has two wires going to each end with the electric solenoid and integrated air pilot assist (usually a poppet) built into the valve actuator assembly.
If you get to dissect various spool valves, study them and play with the pieces, you will find amazing little feats of engineering inside, and valves within valves in reality.
Also, if you see "direct acting" that means a solenoid (electric magnet) donut mounted to slip over one or both ends of the main spool shaft or when only air symbols exists, (no pilot), air directly drives the main spool or poppet. Look at Macvalves.com Crappy website, but the pictures of their designs are pretty cool to read about once you drill into a product category. And they are far and above my fave for reliability, and flexibility in design. It does take work to generate correct part numbers, but they can do about anything imaginable big or little valves and it will do it for years trouble free.
Hi all. Currently I'm working on a VBa script for FTView. I would like to understand a bit better about some commands. 1) What are the...
606
Hello everyone, I'm pretty new to the Schneider world. I'm trying to code on an M340 CPU and i was wondering what's the difference between %M...
1,593
1756-um004_-en-p From the manual above, 1756-EN2TP supports PPP communication, and the 1756-EN2TR has an embedded switch. Is the EN2TR embedded...
2,833
Hi, I’d like to know the differences between these two plcs.
1,751
Hi While running the compare tool for two Projects, I am getting the attached difference in Program and Run. See attached. The difference seems...
1,562
