Poll meter data, as fast as posssible
the_msp
May 2008
Northern Ireland
1,271
I have an R&D project to get data from a power meter as fast as possible.
I have already confirmed response time polling via Modbus TCP.
I now want to now poll it via Ethernet/IP.
The CPU is an L18-ERM running firmware 30.012 programmed with S5K V30.00.00.
The power meter is a Schneider METSEPM5561. I have attached the manual section that covers the E/IP setup.
Questions:
1. Should I use implicit or explicit messaging?
2. Can I set it up as a Generic Ethernet Module? I have tried, GEM parameters: DINT, Assembly instance 100 size 125, assembly output 150 size 64, config 1, size 0.
I get code 16#0127 Invalid output size. What should the output size be for 2 words, as listed in the manual? They are listed as dummy parameter, does this matter?
Questions:
I'm sure you have checked this but has the meter got the right version of firmware in it ?
Hi, Do you have any trick to make a software working when the 30 days demo version is expired? I've tried to uninstall/clean the registers etc...
296
I'm trying to use DTM browser to make make modbus poll from RTAC. I'm able to get the points in first poll object. But not able to get anything in...
127
Hello Guys, I have a Omron 3G3MX2 drive and I want to learn how its Modbus registers work by connecting to pc via Modbus poll software. does...
734
Just curious what the 'standard' is where you are. I assume 11 x 17 (or A3 for ISO people) is standard, but I could be wrong. My shop was using...
31
13,921
i am using modbus pol to trouble shoot a modbus comms issue. I have device communicating modbus over rs485 going through a lantronix express DR...
2,997
