Possibly OT, but it amused me.
I was educated. From that article I learned that if you bit copy a 32 bit IEEE754 float to a DINT and then right shift the DINT 1 bit, then subtract that from the magic hex number 5F3759DF , then take that result and bit copy it back to a float and square it, then multiply it by 1/2 the original float and subtract result from 1.5 and multiply that by itself again, you get a very good first approximation of the inverse square root of the float.
Pretty cool magic trick. I could totally use that somewhere.
A Company I used to work for was shutting down a plant here in Charlotte and we had 2 robots on a line that had been idled since the line they where on was dismatled. For fun we made some "gloves" for the robots and tossed a beanbag back and forth. Took a bit of work but we got it where the robots would spend hours tossing without a miss. Suprisingly it was not as hard as you would think to make this work. We even had different pitches ( fast ball, side arm, lob).
Gotta admit though throwing engine blocks would seem a bit much. I would figure the robot doing the catching would overload its servos.
I liked the part, where the robot stopped to calculate the trajectory, speed, and correct rotation each time. I don't think the author has done any robot programming. Can you imagine the variables to consider in doing this?
Maybe they figured the right "pitch" by trial and error? That would have been exciting!
LMAO. What would the errors cost you? You have to scrap an entire engine block... Now that has to be some expensive R&D
This part seemed a bit far fetched to me also. You throwing from 2 fixed points, It is not like the pitching robot has to figure out where the catching robot robot is at each time. Once it has it why would it need to change the pitch.
OK, I have a challenge for someone. I have a proface Sp-550 WA WXGA connected to a DM BOARD. Because of ,let's just say, an uncooperative company...
29
5,965
Hello, I'm trying to teach myself some 'codesys' I'm not new to PLC's but I am new to codesys specifically I installed codesys V3.5 SP18 on the...
2,855
I recently went to install a new PV at one of our machines. Backstory Old PV Part number 2711-T6C16L1 SER (B) REV (C) FRN (4.43) New PV...
28
5,060
Here's my situation: I have a customer that we've been building panels for for many years. They're a molten metal furnace manufacturer. Up until...
2,932
