Possibly the shortest program in the world
BachPhi
Dec 2007
Los Alamos
640
I came across this program, very short! lol.
Eh, it's 50% longer than it needs to be. You only really need the timer contact on the second rung...
Edit: I'm also not seeing how that is an effective anti-tiedown program..
Never mind that it doesn't accomplish what it appears to be trying to accomplish, that being anti-tiedown. It is pretty short, though. Not as short as it could be but pretty short nonetheless.
Keith
Keith
What are they trying to accomplish? What is meant by "anti-tiedown"?
If this is really a safety function to prevent someone from getting the fingers chopped off, then everyone incl. Bachphi failed to notice the real issue.
Two-hand control must never be made with a regular PLC.
I said "I came across" , I dont even know if and where it located. It's funny that someone built a PLC with two rungs program. But you brought up a good point about safety.
it may be a short program but it don not do what the want it would work the same with just the 2 buttons then the output in 1 rung timer is unnecessary
Did you go to IO Config and see what the PLC setup was?
Like a SLC5/5 in a 10 slot rack?
A 32pt Input?
Aabeck, very funny! I will look on Monday, but I'' bet that it's a micrologix, probably built by some electrician ( no pun intended :=).
Sparky, yours dont look real, so it does not count.
For the sake of anti tie down, obviously it does not do anti tie-down like his/her intention to.
For the sake of safety discussion, It would be wise to use hardware safety relays for the purpose of safety. At the heart of the safety relays are dual channel inputs , and in the case of ATD, it would have the electronic inside to monitor for a standard time max of 500 ms and the double/redundant contacts to power the real outputs.
OK, I have a challenge for someone. I have a proface Sp-550 WA WXGA connected to a DM BOARD. Because of ,let's just say, an uncooperative company...
29
5,963
Hello, I'm trying to teach myself some 'codesys' I'm not new to PLC's but I am new to codesys specifically I installed codesys V3.5 SP18 on the...
2,853
I recently went to install a new PV at one of our machines. Backstory Old PV Part number 2711-T6C16L1 SER (B) REV (C) FRN (4.43) New PV...
28
5,032
Here's my situation: I have a customer that we've been building panels for for many years. They're a molten metal furnace manufacturer. Up until...
2,927
is it possible to convert a csv that is saved in excel to possibly a .xls or.txt file so I can read the values and insert it to a datagrid in a...
17
5,945
