sbasham
OK, I have a challenge for someone. I have a proface Sp-550 WA WXGA connected to a DM BOARD. Because of ,let's just say, an uncooperative company, I cannot get any information about the DM board and the Proface is made explicitly for this company . I need to monitor the 3x addresses that the Proface is reading from the DM board. It is talking Modbus and I am using a AB1400 micrologix PLC to try and accomplish this. I uploaded the HMI program to check what 3x addresses i need to monitor. I am pretty novice when it comes to messaging and do have very little knowledge of setting up or even wiring RS485. I do think I have figured out how to setup the messaging instruction, what I want to know is can I just wire my serial port on the 1400 parallel to the 2 wire connection that the Proface and DM board is using to communicate with, and what pins are the TX and RX on the serial port of the 1400? I tried using the ethernet port on AB to connect to either ethernet ports on the Proface since they weren't being used and could only see one of the comm lights turn on, I believe they possibly are disabled in the software program because they aren't needed for comms to the DM Board.
