Powerflex 753 Cable and Software
Nov 2008
Indianapolis
152
I'm having trouble figuring out what cable I need to connect to a Powerflex 753 to get the parameters out of it.
These VFDs are not connected to a PLC. We are using discrete I/O to control them.
It also appears that there are 2 programs to use to connect.
If anyone has any comments regarding which software is the best. I would be interested in that.
Thanks!
I think you may need to have the Ethernet/IP option board (part number is escaping me at the moment) installed to make a connection. If there is one installed you can connect with a computer and use either RSLogix/Logix Designer or Connected Components Workbench (CCW) which is a free option.
EDIT: Part number is 20-750-ENETR
Regarding the software you can either use DriveExplorer, DriveExecutive or Connected Components Workbench.
For the cable either:
1203-SSS but your PC needs to have a serial port or
1203-USB.
you can also upload the parametrs if the drive is networked to DeviceNet, ControlNet or
EtherNet/IP
For more information check the following link from Rockwell knowledgbase
PowerFlex 4/5 and 7-Class AC Drive: Uploading/Downloading Parameters (CCW)
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/46232
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
110
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,370
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
458
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
570
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
726
