Powerflex 753 not following Ethernet Commands.
HoldenC
Sep 2012
Cumberland, KY
220
I have a Powerflex 753 that I can start with ethernet commands.
However, it doesn't follow the speed reference. It only runs at 60HZ.
Parameter 545 is set to Port 0-Port 4 Reference.
Can anyone offer any assistance ?
Thanks.
When it is running (at the incorrect speed), check parameter 935 (Drive Status 1) bits 10-14 to see what it is actually using as its speed reference.
Does 592 also show 47.5?
Check you don't have a multiplier (549) or a minimum speed limit (522 for forward, 523 for reverse)
Running out of ideas here...
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
109
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,364
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
457
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
563
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
723
