PowerFlex 753 option module 20-750-2262D-2R
CallumMacEwen
Jul 2015
Scotland
42
I am setting up a powerflex 753 using connected components workbench. On the option module you have the relay outputs at the bottom of the card. I have currently got the card connected into port 4 but when I am trying to select the address for the parameter it only comes up with the Digital Inputs and nothing about the relay outputs.
What address for what parameter?
If I drop a 2262D into Port 4 of a 753, Parameters 10-15 on the 2262 card control relay output 0, and 20-25 control relay output 1.
I managed to solve it. First time I had used the workbench. I didn't realise that the option module was another tab from the drive.
Cheers.
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
106
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,358
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
455
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
563
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
719
