Powerflex 753 - Setting up datalinks via Studio
Lovell
Feb 2013
Saskatchewan, Canada
120
I have a PowerFlex 753 V14.002 connected to an L8X processor for control of it. I am trying to add a data link but I have not done so before with this new a drive. They seem to change how the datalinks are setup up with each new revision of the drive. I have been reading the manual but it is not clear to me where exactly to go to set it up. I have tried par 905 but it does not add anything to the data structure. I am using the built in ENETR for ethernet comms (Port 6). Does anyone have experience with setting these up in studio? I do not have CCW installed.
Thanks.
o_O
Perhaps some screenshots? You should add the drive (offline) in your project and then select the data-links and look for the corresponding information you are trying to grab. What are you try to get? current? voltage? Are you saying you are adding the links but not seeing the data?
Bornwild - that video is not current. The new 753 don't show those tabs in their properties.
I called tech support and here are some images of where I had to go to create a datalink for output current.
I did have a comm card, an ENETR. Setup changes if you have a 20comm-E.
Working now. did require to do offline and then download...
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
108
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,360
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
456
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
563
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
720
