Powerflex 753 with Ethernet Monitoring from PLC
mattmc97
Dec 2014
Texas
Hello all...
Have a Powerflex 753 with an Ethernet card communication with a L19ER processor.
Here is my setup...
Local AB PLC will control the Remote VFD drive using Start/Run Level Input on DI1.
2 Wire control, DI1 On = RUN, DI1 Off = Stop
4-20ma Input on AI0 for speed reference input
All monitoring over Ethernet.
I can start drive, I can stop drive, I can reset Faults over Ethernet, I can view Faults, Run Status over Ethernet
So this is 98% working...
I can't figure out how to get VFD Ready to come on over Ethernet. When viewing the documentation it is because I have a Bit 4 STOP on P 933 Start Inhibits.
I did find this in the manual after searching for several hours on this problem...
Run Level (1) As long as a separate Stop command is not issued, the
level alone (no rising edge required) determines whether the drive runs.
When set to 1 Run Level the absence of a run command is indicated as a stop asserted and P935 [Drive Status 1] Bit 0 is low.
When I have Stop Asserted apparently that will also trigger the Start Inhibit which deactivates the Drive Ready Bit.
I would really like to have the VFD Ready Bit work (DriveStatus_Ready) so I can let the user know the drive is Ready to Start / No Problems.
Is there a way to get DriveStatus Ready or another bit that I can monitor other than NOT Fault ?
It sounds like you want to use digital inputs to control the drive, but monitor over Ethernet, correct?
At a glance through the manual it looks as if you would need to convert to 3-wire control, using separate momentary start/stop signals and setting P150 to Run Edge (0). As the section you quoted states, if you are providing a constant run signal then the absence of that run signal is considered a Stop command which will set drive status to not ready.
I actually don't think it is possible to get a VFD_XX:I.DriveStatus_Ready with a 2 wire mode. After working on this for 4+ hours, I finally changed to 3 wire mode. Ran another wire from my PLC for a maintained Stop signal and the VFD_XX:I.DriveStatus_Ready works just fine.
I guess it is viewed as a safety feature. Not sure.
For those in the future that might see this post...
Change DI 1 to Stop Input (Maintained)
Change DI 2 to Start
Di 1 has to be maintained CLOSED for READY, and to start and run the drive
Open Di 1 to Stop the drive or to prevent start
Di2 apparently can be a momentary or maintained signal from PLC. I have sent both and it works fine.
Drive Settings
P158 DI Stop DI 1
P161 DI Start DI 2
P150 Dig In CFG Edge
Yes, to post above. The manual is not clear on that however.
Maybe you have already resolved this but I typically start/run through a digital input, receive a contact signal for Ready, monitor the DriveStatus_Ready bit and use 2 wire control.
I have a Powerflex 753 that I can start with ethernet commands. However, it doesn't follow the speed reference. It only runs at 60HZ...
1,792
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network...
1,438
Hello, I'm setting up an application where I'll have a couple of Powerflex drives commanded from a PLC on a network. However, we want to be...
2,588
I'm relatively new to PLC programming, and have never set up VFD control over ethernet before. I have a controllogix PLC with a simple level...
1,350
I have a Powerflex 753 and a control logix 5000. I have configured my drive into my control logix tree via Ethernet. I am not controlling my drive...
4,301
