Problem in DT name in Eplan
Hitu_hari_om
Mar 2008
Surat
Hello friends,
I have one problem in Eplan drawing.
when i duplicate or insert and device/DT then its tag name shows - (called prefix) another character.
example: Q1 then duplicate > -Q2
i want to remove this - .
i try to remove it through offline numbring settings. then also it not remove.
by deafult it take -. how to remove that.
Pls tell me.
Your Loving Friend
Hitesh
o_O
Are you using P8?
If so
Options> Settings
Projects> yourprojectname> Devices> General
Un-check each item you don't want the preceding sign
This is only for create main function DT. but when i create duplicate DT which has without main function. then it shows prefix ?.
example : K1 (coil is main function) > duplicate then K2. this i try after u tell me. thanks for this.
but when i create duplicate of its (K1) NO contacts then it shows ?K1, ?K2, ?K3....
Please tell me how remove this.
Regards Hearty
Thanks..
Hitesh
Regards Hearty
Thanks..
Hitesh
Not sure about this one?
The only time I get the ? is if I insert a coil on to the drawing and then insert a contact. I've always assumed the ? was asking me what coil to assign the contact to?
I don't normally insert contacts of a relay this way. After I've inserted a coil I drag its contacts from the device navigator. Or insert a part (alt Ins) select your relay from the parts list, after you've placed the coil on the drawing it automatically selects the contact for placement.
thank you very much.
i get it.
i have another query and i had already post my query in forum.
Sub : - " import BOM in Eplan".
i want to import BOM.xls. I want to get this sample format which is except or understand eplan. Eplan is understand .csv or .xml file.
I try to get this .csv or .xml format through Bill of Material's export function. but it is not understandable and it has many row and columns and mixeup.
i want to get only
Sr Tag Description Part/Type Model Quantity
No. Name No. No.
Regards
Hitesh
Never had to this I'm afraid.
I have noticed however, when you get the export parts dialog box up, the file type combo box at the top contains is a list of configuration files. If you open up the configuration files you may be able to edit them to suit your needs?
Like I said I've never had to do this but I did I would:
first export the parts db so you get the correct format
Utilities>Parts>Management
Extras > Export
Once you've exported the current parts database copy your BOM in to the correct columns of the exported csv.
Then chose
Extras > Import
select the same file type you used when exporting then click OK?
no, i m not saying Part Database import & export.
I want to import my BOM in Bill Of Materials. Bcoz this is shortcut way to use all BOM' list.
This is shortcut way and very easy to use our BOM. It has sample format (column, Row setting format) and make your own BOM save as in this type of format then improt. and choose/place one by one part in form.
So i want get this format which has complete arrangment of column and row that is understand Eplan.
I made a hardware configuration and I used IM151-8 PN Cpu and connected two ET200S stations (IM151-3).When I want transfer to ET200S first.I am...
1,775
I have problem about RSLinx Enterprise (FactoryTalk View SE) as follows; 1) I create Device Shortcut name (such as name "ABPLC") and match...
2,220
Hello, could somebody help me with the problem in Citectscada v.7.40: The userename is always set to "system" value. So I can't get this field in...
29
5,790
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
170
