Problem setting up com port in DirectSoft
rwy34ils
Mar 2009
Edmonton, Alberta
73
I am installing DirectSoft Ver 5 (Direct Logic) in my new laptop. When I go to set up the communications link between the laptop and the PLC, the list only shows COM 1 and COM 2 as available choices for serial communications. My old laptop shows COM 1 to 4.
I am using the same installation CD as I used for the old laptop.
Has anyone seen this before? I need to use COM 4 with the new PC. COM 4 is listed in the Windows hardware device manager on the new computer.
I am using a PC Card comm port. In fact, it is the same one I had in the old laptop---I just moved it over. So I'm using the same version of DirectSoft and the same comm card, same OS (Win XP Pro).
I installed Rockwell Factory Talk Machine Edition (with RSLinx Enterprise) on this laptop too. Any chance that is it messing things up?
I agree with Mickey's comment above. My directsoft version only gives me COM Ports 1 & 2 to select. Have you tried upload a fresh program from the PLC (Koyo?). This may reset your COM Port path?
Also make sure that Linx is not running as a Service. It will hold your Com Port big time.
This doesn't make any sense. I think I am losing it.
I turned off the RSLinx, uninstalled the DirectSoft, rebooted and reinstalled the DirectSoft. Same thing. The old computer shows COMS 1 to 4 but the new one only lists COM 1 and 2 as available choices.
Can't use Jarrod's advice to upload from a PLC because I can't connect at all.
Do you have version 5.3 or earlier than 5.3? The release notes mention that 5.3 reenable comm ports 3 and 4 by default. Maybe you installed a service pack on the old computer that you didn't on the new?
Brian
What is this PC card comm port you have?
What does device manager show? ( what comm port does the "PC card take?)
Have you tried to reassign the comm port for the "PC card"?
I'm using a "Socket Serial I/O" card that plugs into the PC slot. When installed, it defaults to COM 4. The device manager recognises it as COM 4.
If I try to change the COM setting I get the following pop-up error message:
"RUNDLL: An exception occurred..."
Good Morning all can you help/advise me im have a configure ge9 driver Called ge9.ge9 path is (C:\Program Files (x86)\Proficy\Proficy...
2,816
Hi Guys, I have got a problem regarding the setting of more than one limit for one input field. I have got four motors for extrusion & One for...
1,672
Good day, I had installed the RSBizWare package. Installed and configured MS SqlExpress 2008. Created the database, and configured the OBDC data...
1,823
Currently I'm using CC-Link modul QJ1BT11N as master station. The CPU I'm using is Q Series CPU, Q02(H). The problem is, I don't understand how to...
2,798
I am working on a heat recovey system and need to regulate a modulating valve in order to maintain a temperature set-point. I have never used...
5,861
