Problem with ActiveX and Intouch
jrespinozah
Feb 2013
Tegus
Hi everyone!
I'm currently creating a window in Wonderware InTouch (WindowMaker) and I'm trying to implement a common dialog control.
I select the wizard/activeX installation in the activeX control tab and install the microsoft common dialog control version 6.0.
After that I go to the wizard/ActiveX menu and select the common dialog from the activeX controls. When I place it on the window all I get is an empty rectangle. When I click on it I see only a properties tag but no event tag.
When I try to insert it into a script, I can see the dialog I just placed ("CommonDialog1" for example) but no methods to select.
If I type something like:
#CommonDialog1.ShowOpen();
I get an error: "Invalid reference or unknown ocx"
I have a comdlg.dll, comdlg32.dll and comdlg32.ocx in the system32 folder. I have also registered the comdlg32.ocx with regsvr32.exe but nothing worked.
anyone know how to fix this? o_O
thanxs!
Check out "Tech Support Script Function Library" from Wonderware support. This library contains many useful functions, like FileSelect() that corresponds with ShowOpen.
Hello,
You could try installing Visual studio or creating a ActiveX 'wrapper' for the control.
Good luck
Stu
o_O
Hi, According to InTouch manuals, this is how to install ActiveX: And this is how it appears on my computer: The "ActiveX Control...
5,527
I'm developing an application in Intouch 9.5(Version 9.5.003). I came up against two serious problems and I would like to receive some help. The...
16,508
Hi, Using FTView 8.20, exact same version on developer PC and customer PC I have problem with alarm view. I use an old project as starting...
3,688
Hi all! In factory talk ME I've a problem with activex recipes (ME recipe 2). When I use them on a panelview is all ok. But when i try on a...
1,864
On site I have two servers (redundant) and four clients with Factory Talk View Studio 7.00. I was making changes on pages with a Factory Talk...
8,418
