problems with slc5/04.
pantojaneto
Guest
P
hello, i nedd some help in communucation betwen slc5/04 and my notebook. i dont know what cable i use and configuration of rslinx and rslogix...
try this first ...
hook a null-modem cable between the SLC and your computer’s comm port ... in RSLinx “add” a driver for “RS-232 / DF1” ... (note: different versions of RSLinx use different names – but this should be close enough to spot) ... when the little “name” box pops up, click OK to keep the default driver name ... on the Configuration screen that pops up, click the “Auto Configuration” button ...
cross your fingers ... if you’re lucky – you’re in ...
if this doesn’t work, let us know ... we can work you through this ...
(one big potential problem: if you’re using a USB-to-serial adapter as your computer’s “serial port”, then “auto-configure” probably won’t work ... because RSLinx “sees” the adapter connected to the port – and not the SLC) ...
the null-modem cable needs connections between pins 2-3; 3-2; and 5-5
next step ... once you've got RSLinx able to see the SLC processor ... go to RSLogix500 ... under "Comms" from the top menu, select "System Comms" ... navigate to the SLC and nail it down ...
now you should be able to go back to "Comms" and choose "Go Online" ... you may have to "create a new file" before the software will connect ...
let us know how it goes ... and don't forget to register on the forum ...
Hello guys, I'm a relative noob at this, but I picked up an SLC5/02 and the UIC cable off eBay and I'm having problems getting it to talk. I have...
2,325
cannot establish comms with my slc-5 with rs 232 or rj 45???
1,512
Hi I'm trying to communicate with an SLC5/03 with a 1747-CP3 SER A RS232 cable. Even moved the jumper inside the module from protect to program...
1,737
Hello chaps i wonder if someone could have a look at the attached file and try to guide me in the right direction as to a problem I have with the...
18
4,660
Good people, Please may you assist with a solution; When I try to download a program to a SLC 5/03 CPU, I get this message ‘No response from...
2,578
