Professional Engineers?
jcr
Oct 2006
Central Florida
91
I enjoy reading this forum regularly. I notice that many people here are running integration/retrofit companies.
I'm curious what percentage of the engineers running these companies and working for them are Professional Engineers (Licensed). If not licensed PEs, how difficult was it to obtain and renew E & O Insurance?
I am the only employee of my company. I don't have a PE license. The last time I asked my agent to get quotes from multiple E&O carriers, two of the three quoted at their minimum premium rates. At least that's how I interpreted their "round number" quotes. The application form I had to fill out asked whether I hold any licenses, but the answer to the question didn't seem to have any bearing on the willingness of carriers to offer coverage.
I expect that the need for a PE license is more contingent on the nature of the work you do and the projects you bid on than anything else.
I'm a PE, the only one of four engineers here.
As Steve pointed out, the nature of your business and the risk assesed by the carrier is more significant than a license. If you only do industrial controls for machine shops your risk may be low. If you do elevators for public buildings, it may be quite high.
In some states you cannot do engineering for systems used by the public if you are not a PE. In some states you can't use the word "engineering" in your business name without a business engineering license, which you can't get unless an officer of the company is licensed.
So much of this varies by state that you would be well advised to get some guidance from your insurance carrier and your local licensing board.
Hello to everyone, I need to comunicate With a Modbus gateway(TCP-RTU)connected throught Modbus TCP/Ip on wincc v7.5 or professional; i will...
266
Hi guys. Is there any way to know what version either Professional or Service do i have for any of my versions installed? I have installed from...
546
Hello Everyone, I have PLC programmed in TIA 16 and this is in Engineering PC. And other PC station have Wincc RT professional V14 sp1. I want to...
2,186
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,256
Hi, I am logging tags every 24Hr in table view in siemens WinCC RT Professional. Every day at 7:00:03 AM a value is logged. WinCC takes value from...
17
3,586
