Profibus Cable
JOLTRON
Aug 2006
MI
692
Hello All. I have a machine that has the Green Fast connect profibus cable in it connected to a Diagnostic repeater. But currently the only profibus cable we have in stock is the Purple Multi-Strand cable. Can these be interchanged with each other or do they have different properties that wouldn't allow them to run in a system set up for the other.
I don't know what you mean by "Multi-Strand" cable. But if both cables are two core cabes, then they do the same work. The only difference is, that the green cable is a flexible, Robotic cable, so if your application involves movement of the cable, the green cable will probably last longer.
I also do not understand the "green" profibus cable. To avoid mistakes, profibus cable is normally purple. Green is usually used with ethernet/profinet, but that cable is 4-core, so it cannot be mistaken for a profibus cable.
Helukabel has a "greenish" Profibus cable with bus and power in the same cable. Also cannot be mistaken for a normal profibus cable because it has 5 cores.
What is the exact make and type of either cable ?
Firstly, you can download the whole "Industrial Communication" catalogue from the SIEMENS site. This contains all the details you may need. Now, as for the green cable, both Ethernet and robotic Profibus cables are green. The difference is that the Ethernet is, as you said a 4-Core cable, whereas the Profibus is a 2-Core cable. Also, the Robotic Profibus is a light-green and the Ethernet is a darker green hue. The Robotic Profibus cable is dubbed " FC Trailing" Product code: 6XV1 830-3EH10.
Personally, for inter-computers/HMI Ethernet, I use my standard "Category5" Ethernet cables (cheaper). However if you're planning on an Etherner Fieldbus (PROFINET), you should consider using the original SIEMENS Ethernet cables.
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
328
Hello everyone, friends. We have a machine where our main CPU is a Siemens S7-300, but with different makes and models of drivers, and modules...
18
3,797
Ok here is the problem we have a Siemens DP PLC (Master) and RIO ( slave) at the end of a Fiber Cable that runs through a Slip ring via OLMs...
495
Hello guys, I need your help regarding the proper termination of Profibus cables. I now that in theory in order to minimize the noise and to...
3,661
Dear All, I want to know, due to aging, temperature and humidity present in the room, the power cables got hard. This hardening does effect the...
1,645
