Profibus / Modbus
Jezz
Dec 2002
Kendal
399
Hi all just a quick one what is Profibus and Modbus , are they just types of remote I/O and if so what's the difference
Thanks Jezz
:confused:
ModBus is open protocoll. Profibus is nice try of FieldBus, no multimaster, master-slave polling system, no COS cababilitys, no multicasting, no broadcasting, no etc..
FieldBus must be more than RIO-bus, purpose is remote intelligence to field-devices as VFDs, abs encoders, control-valves etc..
See the documentation
Get the real info at:
Profibus Trade Origanization
Profibus DP has a multimaster capability. It has a means of passing a token from one master to the next so only one master controls the bus at a time.
Master-slave polling is basic. A SST profibus master can update 6000 I/O points a millisecond using polling. ( The data exchange state )
I agree with the no change of state capability, but Profibus DP doesn't need it as it is so fast.
Profibus does have the something like mulitcasting/broadcasting in DPV2. I haven't seen a master that implements it yet.
Profibus also has isochronous data transfers.
The problem is that few of the master implement more than the basic features. Even worse is that many don't implement the basics correctly and the Profibus Trade Organization does nothing about it.
We are building a new product now and are making a Profibus DP interfaces. The problem is that there are a lot of features Profibus DP supports but there is not point in implementing them if the masters don't support these features. This is why many think Profibus DP can't do this or that. The real answer is that most don't need the extra features and it costs money to implement them.
Modbus is not a field bus. It is a protocol. Some have combined Modbus with RS485 which works well.
Modbus Plus is a field bus that has most of the features Seppo mentioned above. It was way ahead of its time. Modbus plus is great for talking between intelligent devices. Until Ethernet/IP, Modbus Plus was one of my favorites.
See Modbus.org
Hi Everyone! I am feeling some troubles while dealing with Profibus and Modbus. Is there anyone who can help me out in following questions? 1...
2,514
hello I use S7-317 CPU in new project to control production line. I use two old DC motor drives...in old configuration they were controlled...
1,766
Iam working on link PLC S7-317 2PN/DP as master using profibus to two old slave speed drives which have only modbus (rs-485) after search I...
2,035
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,294
Hi all I want your advice for my problem : I have two PLC control systems , first is an old one and I use an Intouch Scada system to monitor and...
3,403
