Proficy IFix 5.5 IGS 7.58
Patrick
Apr 2007
Washington State
96
I posted this on the Proficy Fourm. I got no answers.
some one want to try?
I am in the process of setting up the addressing for the controllers in our plant. So far I have the Modicons and Allen Bradleys on line.
My problem is getting one particular AB on line. The routing for this one is through a Controllogix gateway out a DH+/RIO card to another DH+/RIO card to a Controllogix L55.
This is the only Controllogix that I have on DH+. Everything else on this routing is working. The PLC5 is routed
Model DH+ Gateway/PLC-5
I.D. <172.30.110.30>,1,0.A.11
My problem is which model do I use, and what I.D. should I use?
This unit has an address of 12 Oct. 10 Dec.
Thank you.
Pat
Hi I want to press a button on the HMI screen and write to a bit within an Integer within a control logix PLC. The iFix version is 5.5 and using...
2,404
Hello, During runtime I change values of some internal tags (i.e. F_CV of DO tags). And I want them to be saved when I switch runtime off, and...
5,463
Hello All, Can any one assist me with trial version of PROFICY IFIX software as i am new this. Thanks,
1,938
So, Im a wastewater operator and also a digital designer/ web developer and im trying to learn Ifix 6.0 or 5.9 but I cant find any resources to...
1,346
Hello guys, I’m doing some new programming for our WWTP in town. I need to utilize existing SCADA tags for my new programming. I’m used to...
5,491
