Profinet Input Map Swapping on Byte Level
kevilay
Feb 2009
Ontario
174
Hello Guys,
Device: Siemens Step 7 5.5 IM151-8 PLC &Festo CPX valve bank w/ CPI Module
I am using a festo valve bank with CPI inputs. The CPI networks has 4 chains 32 inputs on each. On chain one I only had 1 16pt block, then I moved onto chain 2. However I didnt realize that chain one still reserved the 32 inputs. So all my IO on my machine is all offset. In the hardware manager in siemens it brings all the inputs in as 1 group. Byte 50-65. If I could Shuffle it around on a byte level It would save me hours of relabeling.
Thanks,
Kevin
Hi, I have a setup of one master s7-1200 - three slaves s7-1200 On each of the slaves there is a HSC on a motor for positioning. It generates...
1,087
Hello, I'm working on project where I'm using an S7-1200 PLC, and I'm working with 3 devices that I'm connecting on a Profinet network. I...
2,266
164
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
394
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
700
