If you're using Portal for an S7-300, the method outlined in your link should still work. In the properties, you can also see checksums for the individual blocks.
In a 1500, I know you can get the checksum of the safety program, but I'm not sure if you can access anything for the standard program. I don't even think you can see checksums offline. Maybe V14?
However, portal does at least have the online/offline compare, so you should be able to quickly see where the project is different. Still need your computer to do it though :/
