Program Change Detection with Portal
JDCROCKETT724
Jun 2010
Michigan
249
Is there a way I can detect a change in the PLC program, and flag a bit if one is detected. I found that there is a FB that is called Prog_Check for V5.5, but I don't see anything for portal.
https://support.industry.siemens.co...tia-portal-v11-v12/105704/?page=0&pageSize=10
I've done the same thing with AB plc's and it comes in handy. When ever a change is detected I create a date/time stamp and record the last 20 changes. It is a great way to determine if the customer was messing around with the program when the machine "Suddenly" stops working. It's nice to know if it is a bug that we missed or something they did. You still have to run a compare tool on the program to see if what they did caused the issue, but it does tell you if they were in the PLC around the time is stopped working.
If you're using Portal for an S7-300, the method outlined in your link should still work. In the properties, you can also see checksums for the individual blocks.
In a 1500, I know you can get the checksum of the safety program, but I'm not sure if you can access anything for the standard program. I don't even think you can see checksums offline. Maybe V14?
However, portal does at least have the online/offline compare, so you should be able to quickly see where the project is different. Still need your computer to do it though :/
How do I change the IP address of a EN2TR module in a remote rack in a running PLC in Studio5000? When viewing the module properties while online...
2,639
Good Afternoon , I was emailed a RS Logix 5000 program that is version 32. I only have version 28 , on this computer here at the house. I...
4,528
This is a CompactLogix L33ERM, version 30 (31 is too unstable on my machine to work with), with a Kinetix 5500 drive. I have a program where...
2,042
i want to change Codesys program wago plc model from 750-881 to 750-842 some guide me plz thanks
3,301
Hello all, Kinda new to Crimson 3.0. Looking to run a program when a string tag data value has changed. I haven't seen any setting to do that...
6,814
