There are 2 or 3 ways to get into the Address Picker: Edit Mode. "Ctrl-T" brings it up, or from the top menu you can select "Program, Address Picker".Still haven't quite figured that out yet...
Another way is simply to click on the instruction that you want to edit, then on the pop-up menu, click on the box to the right of the Bit Memory Address. That brings up the Address Picker: Pickup Mode. Click on the box in the lower left corner to switch to Edit Mode. Then you can change or add new address descriptions.
