rohit_plc Member R Join Date Jun 2013 Location delhi Posts 81 Dec 18, 2013 #1 i have micro logix 1400 i need programming cable pinouts for this.....
kolyur Lifetime Supporting Member + Moderator K Join Date Oct 2004 Location Wooster, Ohio Posts 1,602 Dec 18, 2013 #2 You're in luck, there was just a post about this: http://www.plctalk.net/qanda/showthread.php?t=84235
rohit_plc Member OP R Join Date Jun 2013 Location delhi Posts 81 Dec 18, 2013 #3 can u please give pinouts not clear from this document..
kolyur Lifetime Supporting Member + Moderator K Join Date Oct 2004 Location Wooster, Ohio Posts 1,602 Dec 18, 2013 #4 Do a Google search for 1761-CBL-PM02, that is the cable used for programming. Many pinout diagrams online.
diat150 Lifetime Supporting Member D Join Date Mar 2006 Location Louisiana Posts 1,474 Dec 18, 2013 #5 just use ethernet.
califflash Member C Join Date Jan 2011 Location Houston, TX Posts 257 Dec 18, 2013 #6 Second Ethernet. The days of programming over serial are numbered.
Bullzi Lifetime Supporting Member B Join Date Jun 2012 Location Colorado Posts 1,530 Dec 18, 2013 #7 +1 for Ethernet. I only use serial when I have to or so I can set up the IP address when BOOTP isn't working right.
