programming help
dcharate
May 2005
i m using rs logix 500
i have probs with subroutine
first instruction in subroutine get executed without beign called
& can i unlatch output in main program when it is latched in subroutine if no what can i do to unlatch them
can u explain how to use sequencer inst. what is its importance?
dcharate sent this to me in a PM
hi i m working on mocrologix 1200 with rs logix 500
plz help me with subroutine
first instruction in subroutine get executed without being called
how to unlatch an output which is latched in subroutine
also can u give me sample program for conveyors with interlocks
Post your code and I am sure someone can help you out.
Thanks,
Bob O.
jvdcande,
I think he pick the wrong Bob to PM for advice but I'll take it.
Bob O.
I have never seen a subroutine that executed when it isn't called.
However if you called a subroutine, latched some bits and then no longer call the subroutine, the bits will remain latched. Conditional subroutines are tricky, and I wouldn't recommend them for someone just starting out.
Post your code and someone will help you out.
that depends upon how you are calling JSR
if it is directed to powerline then first JSr will run and excute therung provde the condition.
sandymax
Open the Xref and scroll down to the bottom.
The references to "U:x" are jumps to subroutines, where "x" is the file number.
Also check if S:29 "Fault Routine", S:31 "Selectable Timed interrupt file" or S:46 "Digital Input Interrup file" is set to the file number in question.
There is also the rare chance that the file is called with indirect addressing. Search globally for "JSR" and "SBR".
Don't mean to be negative, but...
If dcharate can not program a simple application i.e.
How could we expect him to understand that...
dcharate we need to see your code to help you...
:rolleyes:
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
959
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,983
I don't have much experience in programming. I can do simple configuration. it is like this. i want to add something to the existing ladder...
39
6,268
Hello there, I'm practically new to the PLC world, I'm quite familiar with Siemens TIA Portal but I'm currently tasked to program Schneider PLCs...
1,877
Hello All, As you can guess by the title I am a total noob to programming PLC's. So my problem is that I have an old Pallet wrapper that uses an...
21
4,947
