Proxy variables in Proficy ME
godfrey
Apr 2002
Charlotte, NC
412
Looking for help to create proxy variables in an existing Proficy ME project.
Can't find it in the help file. Creating a new variable does not give me the option.
As far as I know, you don't actually create proxy variables.
When you use a variable from one target on another target, the proxy is created.
In my projects, I have a target named PLC and a target named HMI.
I add an object on the HMI and use PLC.MyVariable1 for the object.
After the HMI target is validated, MyVariable1 will be listed under the HMI target and will be a proxy variable.
I think there is a method to share variables from one project to another.
This might also create proxy variables.
How do I export proxy variables to a csv list ? I use a QP+ to connect with a Rx3i and mapping some of the PLC variables to the QP for alarming purpose, but I can't seem to export them, only internal variables in the QP can be exported.
It would have been better to start a new topic.
There is no way I know of to export proxy variables.
You can export the variables from the PLC.
I put Hmi in my variable names so I know they are used for the HMI.
If you use symbolic variables, they must be shared to be used. I can sort by the publish column to find these variables.
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
245
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
325
HI all, i looked through the threads and didn't see anything that was close to my problem. hopefully someone will have an answer. I am trying to...
685
Yo!!! I have a weird one. I am drawing a simple HMI for a machine to allow the maintenance team to calibrate a scale without needing to get the...
1,510
What is the difference between the OPCWorx Proxy (which seems to be legacy), and the OPC UA Server? Both can be used to share data between redlion...
1,695
