pump control by plc
phaniraj kvs
Guest
P
My problem is that i want to control water level in a over head tank using a plc .that means to switch off the pump when the tank fills and to switch on the pump when the tank becomes empty .
I am not able to find a device that will give signal to PLC indicating the water level, a sensor that gives a actuating
signal to plc regarding the water level .
So please give me a solution ,so that i can automate my over head tank using a PLC.
Floats are a good choice, and another is electrode type level switches. Warwick, Omega Engineering, and others make them.
A more elegant solution would be to use a pressure transmitter at the bottom of the tank and an analog input on the PLC. The upside is now you know the tank level continuously and you can adjust the high/low trip points at the PLC without physically going into the tank. The down side is slightly higher cost, but by the time you include installation and wiring I'm not sure that is significant.
There needs to be a warning that you are posting in a really old thread here. I've seen it used in other forums (as well as something that warns you when someone beat you to the punch and posted something before you did). 2 useful things this forum is lacking.
Hi guys, I'm currently a PLC student in my 40's. I just started going to a local tech school, and really am kinda slipping in the mud trying to...
18
13,859
I'm looking for a solution to a problem we are having in our water treatment system. We add a lime slurry to the water prior to it going through...
29
11,001
hello, i am a entry level student studying plcs. i was wondering if anyone could help me with a problem. i need to control 2 pumps. using a...
3,640
Hi everyone, I am a newbie and I have trouble in the control sequence. I have a system with 4 pumps. The required: Ex: Push a button to start in...
21
2,767
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,768
