Pushbutton-like "button"
rpoet
Jun 2008
New York, NY
536
All,
I''m on the hunt for a device that looks like a 30mm momentary pushbutton, but instead of contact block(s) behind the panel, I need an "actuator rod" to press another switch behind the panel.
Let me explain:
I have to marine-ize a non-weatherproof piece of gear with a pushbutton that won't survive more than a few days out in rain and salt air (top deck of a ship). I can't alter the device with the pushbutton (warranty reasons) but I can place it within a larger, waterproof enclosure.
I need to push that pushbutton from the outside of my enclosure. Ideally, there exists a 30mm NEMA4X "pushbutton" with an adjustable rod or finger on the back, that I can size to my length requirements. Does anything like that exist? My guess is that something exists, but I have no idea what it's called; my Googling has so far been somewhat fruitless.
I've found these offerings, but I'd prefer something in 30mm as opposed to 22mm:
https://www.cesco.com/Square-D-by-S...A86102--FL-Reset-Pushbutton-Operator/p1963922
https://www.grainger.com/product/30XF48?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!50916779397!!!g!342321660881!&ef_id=WcUGRAAAATTzNOe2:20171115125447:s&kwid=productads-adid^50916779397-device^c-plaid^342321660881-sku^30XF48-adType^PLA
Thanks,
-rpoet
Hey guys ! How do I use the pushbutton fucntion block and test it ? I put the FB on the worksheet, put the signal tags, but I dont know how to...
636
Sorry for the basic question: On my HMI, I've created a button labelled SAVE to save the current values (distances in mm). It's not linked to any...
22
2,290
Hi all, (This is with FTV SE v12) I am trying to use the Push Button -> Button and I would like to have the same color for the border and the...
1,630
1,090
Hi all - (Using Logix Designer 33.01, View Designer 8.01 on PV5310) I'm having trouble with pushbuttons either not appearing (in emulator or on...
1,470
