PV600 Comm Issue
GoPackGo
Oct 2008
Wisconsin
Hi All,
We have a PanelView 600 -- 2711-B6C2, USB to DH485 converter -- 1747-UIC, and DH cable -- 1747-C13. I've installed the drivers for the converter and configured the driver in RSLinx(followed the instructions in the manual).
The PV 600 is brand new from the box, I'm attempting to set up communications with it via laptop. On the 1747-UIC, USB and OK LEDs are solid green, but nothing from the DH485 side. On the PV 600 itself, both Comm and Fault lights are flashing. I've matched up the Comm settings, tried changing the Node # in the PV, and Station # in the driver settings in RSLinx.
What am I missing here? Thanx in advance for your time and insight!
Double check the comm port the UIC took under windows device manager.
Then match this in RSLinx.
The baud rate must match. The node addresses must be different.
If possible post a screen shot of of your RSLinx set-up.
Success
This morning I was able to upload a program from a PV we have on a machine. Then when I hooked up to the new unit, everything went smooth. I guess chalk it up to being a Monday...
Good Evening Everyone, I have a PanelView standard 600 touch only 2711-T6C2L1X(DH485) and I have a 600 T6C20L1(Ethernet). Is it possible to take...
1,924
I am trying to program a stubborn PV600 and having comm problems. Once source says I need a 2711-NC13 cable with just 2-2,3-3, and 5-5. Another...
1,215
I have a PV 600 (2711-T6C16L1, Ser-B Rev-C, FRN- 4.43) It has a RS 232 port I believed is used for printing, and a RS 232 DF1 port. I am...
28
9,006
Hello experts, There's an existing PanelView600 (2711-K6C5 which has only RS-232-DH485 communication port) communicating to a MicroLogix 1500 (it...
35
15,403
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
425
