PV600 with RIO connection too slow
BestTime
Jan 2016
Ontario
89
Hi.
I am connecting and started to program the SLC5/03 (L532, E, 8, OS302 C) cpu
with PV600, RIO. Finally I got green light on the scanner card.
But: the response is too slow. On PV600 I programmed only 1 momentary push button.
When I press it, it takes 3-6 seconds until I see the output comes on on PLC. In the mean time I released the PB the output is still on for about 2 seconds.
Is this a PanelView Standard, or a PanelView Plus ?
Is the pushbutton part of the discrete I/O image, or part of a block transfer ?
If it's part of the discrete I/O, there must be a "hold time" or other button object configuration error, or an extremely poor network connection that is frequently erroring out and reconnecting.
If it's part of the block transfers, you need to put in some logic to measure how fast the block transfers are operating. Generally I just put retentive timers on the /EN bit and reset them with the /DN bit.
Hi guys. We currently have 8 pv600 in the factory, and im looking to make a couple of modifications to the program in the pv but the thing is...
4,983
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
432
Hello, I've recently tried to upgrade my PLC controller from a L72 to L84ES and everything seemed to work, all buttons and screens as far...
2,645
I imported the pva into Factory Talk View Studio and it gave me some errors. Alarm message Ack option not supported. Blinking color images are...
1,794
I'm trying to set the date and time on a Panelview 600 plus 2711P-T6M20D8 SER A. I looked for a white square to pop up in the lower left...
1,804
