Quantum: controller type does not match the PLC type set in configuration database
dbmcbb
Aug 2011
Omaha, Nebraska
Hello experts. I am replacing a Quantum 140 CPU 113 02 controller and get the message above. I have tried usig EXECloader to load the stripped executive becasue the configuration for this controller is set to the 02s version. After I load what I think is the stripped executive, a rescan in EXECloader shows that the PLC does not have the 0xS firmware, it still has the 0x firmware. And when I connect to the PLC to try to download the configutation, I get the error in the subject. Can someone help?
The replacement is a higher PV, then the original. PV00 vs PV07.
I even tried uploading the firmware from the controller with the faulty Modbus port and loading it to the new controller, but still no sucess.
I appreciate any help!
Do you not have access to the unity app? normally you would just change the CPU firmware version in unity's cpu config and do a download to the new cpu.
Hi all, Yesterday I tried to reset the Quantum 140CPU65160S controller by pressing the Reset button available on front panel under the cover...
2,569
Hi - I am not familiar with Schneider PLCs at all, but have a question about a a Quantum 140 CPU3110 10 Unity Controller. It has "modbus" and...
3,123
Does anybody know what material I will need on the PLC side to communicate with a Hardy controller ? Hardy says Ethernet/IP, Modbus TCP...
2,380
Hello, I'm trying to access a quantum PLC using ProWorx. Network explorer can find it on modbus plus node 12 but it's status reads "BUSY...
4,462
I worked earlier in a company which is having Modicon quantum PLC. The CPU is 140 CPU 43412A. Now there is a problem,the CPU get empty.So they...
4,278
