Question regarding writing to shift registers
rcflyer91
Jun 2011
Texas
30
Greetings. I have a challenge here and am seeking any assistance ya'll can offer.
I am writing a value into Inspection Camera shift register (B23/144) based on a pass or fail signal from a vision system. I am writing B23/150 into the Register on Main Turret B23/160.
If there is a 1 written into the Main Turret register at the B3/166, The bottle is not rejected.
My problem is that the label dispense does not always run (no bottles present) I am continuing to write the same value from B23/150 into B23/160 because the turret turns all of the time. I would like to just write the initial 1 or 0 from B23/150 into B23/160 and then write 0 until the next inspection takes place.
Any ideas?
AB SLC5/03
Thanks,
Jim
You're going to have to write the "0" back into B3/166 based on a time event or sensor input. A time or condition will have to occur AFTER the "1" is entered in order to make the change back to "0".
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,045
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,145
Hello, I have a question regarding the analog output modules on a AB Micro850. I'm not getting an output to my valve and when I put a meter on it...
1,543
Happy new year everyone. This is more of a Electrical engineering question than a PLC one. Can a Motor and a VFD that is rated for 240/480...
29
10,044
This may be a simple question. I understand the concept and application of analog modules (i.e. Compactlogix) for transducers, and outputs for VFD...
2,121
