Quick Question
ChrisBotts
Apr 2003
What would happen if I were to go in and erase the whole program as well as the Data Memories and retype the code over again? Would or could this cause a problem. I have a copy of the program as well as the DM vaules.
The act of erasing the program and data memories should put the PLC back to its out-of-the-box condition. Be aware that some PLCs have the ability to read from non-volatile memory on power-up, so clearing RAM may not be all you have to do. You'll get more specific answers if you include the brand and model PLC you're talking about.
Boy, you've got an old one......
Here is the procedure to completely initialize the C120 PLC to the out-of-the-box condition.
Be sure to do an I/O Table Register after you clear the PLC or you will get big time errors:
I've played with those plug-in programmers, they are scary.
I remember having to add a n/o bit for something I had wired to the controls. I broke out in a cold sweat.
Funny now I think, I bet most of us have had the cold sweats at some time or other, hehehe.
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,295
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
912
Has anyone come across a 3 turn potentiometer that is panal mounted with either a 22 or 30 mm hole? I have been looking but nothing so far. They...
20
4,776
Hi, I am just learning CCW, finally got connected to a micro820. I'm wondering what the Version number means. The program that was already in the...
1,638
How do I measure if I am getting a signal out of the plc output? All of the outputs are giving me the same voltage, however I am certain that not...
2,189
