Raspberry PI as VPN Hamachi Connection
Sphinxj
Jan 2014
Washington, MO
24
Hey there everyone. What I am trying to complete is deploying this PI in the field with a service tech. They will connect the PI to a local switch in a machine that has components with static IPs attached to it. The PI will either connect to the internet through a wifi adapter, or through a cellular adapter. The PI will have a static IP so it can communicate to the devices inside the machine. Back at the shop, I want to be able to connect to that network so I can make changes to the devices in that machine (PLC, HMI, etc).
I have Hamachi loaded on the PI right now, and I am able to access it from a different network, but I can not see any of the connected devices. I am sure I have a setting incorrect or something. Has anyone got this to work yet? I have the pi set as a Gateway through Hamachi.
I don't have a clue how this software works but it can't access anything the RPI OS can't access by itself.
So if you log in to the RPI can you access / ping or whatever the devices you want to talk to?
Also, have you setup a static network address on the RPI?
The way I have it set up at the moment has a static address set for the ethernet port. I have a wireless ethernet adapter to access the internet that is set for DHCP. I need this wireless ethernet adapter to remain DHCP as I will not be able to set a static IP when it is in the plant.
I can see the RPI through Hamachi, but I can not access the PLC or other devices on the network.
I do not know Hamachi but i have used other vpn software and then i need to enable ip forwarding on the remote computer (the rpi in this case) and on the local computer i add a route to the remote network.
Example: (from the command line type) route add 192.168.1.0 mask 255.255.255.255 7.207.172.255 metric 1
(192.168.1.0 is the base ip of the remote network, 7.x is the vpn ip)
I will check out Hamachi someday btw, i have too wanted to utilize a rpi for this purpose :)
I have not added the routing yet, and maybe that is my problem. I will try to tackle that in the next few days. Thanks.
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,553
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,739
Hello! I have seen some stuff with people using a raspberry pi running some sort of open PLC software to run some test examples. Has anyone...
25
6,551
I have a customer who has 20 of our systems using PanelView Plus 7 Performance Series A terminals. With how hard it is to find printer nowadays...
1,621
Hey guys, I'm new to PLC, Although I was wondering if I could establish a handshake between the CJ2M and Raspberry pi over Ethernet...
2,394
