RE opening .S7S file
RockyNivas
Mar 2019
United Kingdom
57
Hello Everyone,
I have an .S7S file. Can I open it using TIA portal V15.1 ?. Can anyone please let me know how to open this. I am lagging of Simatic manager to open. Is there any other way to open this ? Please let me know.
Thanks in advance.
The .s7s file could be from a STEP7 v5.x project. But it is not enough with just that file. The PLC program consists of many files in a specific folder structure. If you manipulate single files, you risk corrupting the project.
When copying or moving STEP7 v5.x projects, you should use the archive/retrieve functions to get the complete folder structure.
If you do have access to the complete STEP7 project, then there is a migration function in TIA. But that is another topic, not as easy as one should think. I would not attempt it without good knowledge of both STEP7 classic or TIA.
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
78
Very similar issue as the last post I had here with communicating our Linux Gateway to an AB CompactLogix controller. I have assigned a gateway...
176
Hi All, I am trying to program some new Versamax micro PLCs through PAC using some programs saved in our archive however whenever i go to import...
125
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
109
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
422
