ReCalibrating Encoder
banfield
Jan 2013
banfield
Hi everyone! First of all, thank you for taking you time to read this post :)
This motor (AB MPL-A430H-SJ22AA) was disassembled to change the bearings and then, assembled but now, I have to recalibrate the encoder, so does anyone know how to do it? The model of the encoder is SRS50-FFA0-S01.
Thanks in advance!
Rockwell have a procedure but I do not think that it is available to us normal people, you have to get the phasing correct, even if you marked it when removing it there is no guarantee thay you put the encoder back exactly where you removed it, I beleive it has to be set up with 10ths of a degree accuracy or better.
Alan
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
240
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
328
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,043
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
216
Hi all, I am working with an incremental encoder (ABZ signals, 360 ppr (so 1440 counts per rev)) to replace the existing "manual" encoder wheel I...
51
2,636
