Recovering Siemens Protool Project
ThePortLion
Oct 2007
Ireland
58
Hi Guys
We have a Siemens HMI here that we don’t have any real backup for.
The vendor went out of business and all we were left with was a second compact flash card “backup”. There is a CF card in the back of the HMI so i assume the one I have is a copy of that. It looks like it was developed in protool.
The HMI is an MP370 (6AV6545-0DA10-0AX0). We’re using protool V6.0.
I want to recover the HMI application. I don’t mean merely backing it up, but recovering the original (pre-compiled) project.
All i can see on the flash card is a bunch of .dll files, a .fwd file which I believe is a runtime file and a .pwl file which i understand contains user data. I could be corrected on this.
There's also a .exe file. I've attached a screen shot of some of the folder contents. I d'ont see any .pdb or .pdz project files in there.
My question is, can i recover the project from this and as i suspect i can't,
is there any other way round this?
Thanks in advance
Unfortunately you cant automatically recover the source code from the image file.
You have to reverse-engineer the HMI program.
You have to identify all the PLC addresses that are linked to HMI elements, and recreate the program in the same way.
I am not sure if you can actually run the file PDATA.FWD on your PC, if you have Protool Pro. If so, there is the odd chance that you can connect to PLCSIM which will help the reverse-engineering a lot.
Hello friends, long time lurker first time poster here. I have a, lets say, unique situation with a CompactLogix PLC where we've lost the program...
377
Does anyone know if there's a technical reason why Siemens HMIs can't have the program uploaded from them into TIAPortal as a project file, or is...
807
I am new to PLC programming and I am looking for some expert guidance. I have a PLC C20 controlling a deposition unit. Apparently we let the...
1,300
Hello, We upgraded our PLC to L85 but then realized that some old software no longer runs with it. We still have the old PLC, but we can't...
2,374
Hi, After having an unexpected electricity shutdown and then restoration of electricity, my PLC went into error mode (blinking Error LED). I can...
21
6,643
