I recommend you get the Molex/ODVA Tools which support device detection and let you test some functions of the EtherNet/IP device. It is free of charge.So it appears that it doesn't show up in FTLinx (or RSLinx) at all, so my next move is to upload the configuration into Crimson 3 and see if I can get the information that way. However Crimson 3 and 3.2 both just give the error: The device does not contain an uploadable image. I'm confident I have the right IP address this time because if I point it to a different one (with either nothing on it, or a non-Red Lion device on it), I get a different error about being unable to open the communication port. Interestingly, I also get the same "unable to open communication port" error if I try to upload from Crimson 2 and Crimson 3.1. Not sure why 3.0 and 3.2 can "see" it, but not 3.1.
Ethernet/IP. It looks like I don't actually need it after all - I was just trying to get some information about it and thought I might be able to do it in FT Linx. A device was showing up at it's supposed address with a yellow question mark, but it turns out on further investigation, that the documented address is wrong and that was an entirely different device (for which I also don't have an EDS file, but that's moot).
Crimson 3.2 - Programming software for FlexEdge® controllers.
Crimson 3.1 - Programming software for CR3000 & CR1000 HMIs, Graphite® HMIs and Controllers, and E3 I/O™ modules.
Crimson 3.0 - Programming software for Graphite® HMIs, G3 and G3 Kadet HMI operator panels, Graphite Controllers, Modular Controller, Data Station Plus and E3 I/O™ Modules.
Crimson 2.1 – Programming software for PXU meters and controllers, PAX2, PAX, EPAX, LPAX, LD, CUB5 and ICM8 meters.
Crimson 2.0 - Programming software for ICM8, EPAX, LPAX, PAX®2, PAX, T16, T48, P16, P48 and CUB5 (Software Version 2.0 or higher). Also used to program the following G3 HMIs: G303 and G306 with monochrome display.
Crimson 1.0 - Programming software for the original Modular Controller series.
Potentially answering my own question - I just saw an option in the "Link" menu, named "Support Upload", which by default is unchecked.Is it possible to download the configuration in such a way as to not permit uploading?
Why is that option unchecked by default. Find me the software engineer responsible and a large fish
Odd. My install of Crimson 3 is brand new (recently set it up on a new ARM VM and haven't used a Red Lion product since), and that box was unchecked.
Not sure about the memory card, I will check next time I'm in front of the box.
The datastation just handles a modbus interface on a small packaged skid. Nothing too difficult, and the OEM is still around and generally helpful, so I can probably get a copy of the config.
I've tried Auto Ethernet 1 as well, with the same results.
You are a good person. I think you and I would get along....I always answer yes to that critical question when prompted to do a download and the software "remembers" my choice?
