Red Lion MPAXI meters
DLMUK
Jun 2013
Southampton
311
I have a handful of MPAXI meters supplied by Red Lion but I am having trouble communicating with a PC via the USB card. Hopefully someone here may be able to help.
I have tried on both the older and newer versions, the one I have to hand is MPAXI030 date code 13144.
The problem I am getting is I can connect to the device using Crimson 2 and upload a database to it. However after the first upload I never seem to be able to reconnect. I go on the menus, Link > Options > select USB. All other options are grayed out.
Does the serial comms settings (section 7) on the database have any bearing on being able to connect?
Cheers,
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
268
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
109
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
