Red Lion - Parker comms issue
Dec 2012
uk
Hi all,
I've had this problem for a long time now, but have always found a way round it, decided it was about time I try and solve it.
Not sure if the problem is on the Red Lion side or the Parker SSD side but it is as follows;
Using a G304K I set the RS-485 mode to SSD Drives 635/637 (I know I am now using the 638 drive but the problem was first seen on a 637).
The Drive is a Parker SSD 638 with four wire RS485 comms module.
The problem is this and is the only comms issue I have found;
I can write directly to a variable from the G304k to the 638 with no problems, the value I enter is correct to the value received by the drive. However, when trying to read a Variable back from the drive the value makes no sense, as a count of 1 on the drive variable comes back as 16777216 on the red lion display.
Now I have tried scaling but this only works up to a small limit before the display starts going negative.
The only way I have been able to get round this so far is to set the red lion tag up with a trigger, so when the variable changes another red lion tag is increased by 1. This works fine up to 300 counts a minute, but we have counting needs up to 4000 counts a minute.
The drive has been tested and seen to work up to 3000 counts a minute so far, but I simply cannot display this value correctly on the red lion screen.
As far as I know I only have this issue when using RS232 or RS485. CanOpen works perfectly, but isn't available on the G304K.
So if anyone else has seen this, or knows of a way around the issue, please let me know.
Regards,
Garry.
Hi, tried everything so far, I'll have another go with this but haven't been able to solve it yet after 2 years. Always found another way to do the required job.
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
268
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
280
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
112
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
227
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
