Redlion Pax I meter with Profibus
dineshkaul
Sep 2010
Noida, India
We are trying to use a PaxI meter with Profibus card for displaying values sent by a Siemens PLC, but PLC programmer is facing problem -
"proffibus occupies a space of 84 bytes when used , To display a 8 digit value if it takes such a big space imay be i would run out of resource in my plc if i use 8 - 10 meters . is there ant other option which consumes less space and i can display only one 8 digit value instead of using PAXI- with 3 counters and one rate and many other function which are of no use to me. "
Could you please help ? Is there any way to get around this without sacrificing the Pax Meter.
Thanks.
Hello,
If you contact me at [email protected] I can have a special GSD file created for you which consumes less bytes. Please provide any information regarding the data you are trying to access.
Jeremy
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
126
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
228
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
662
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
829
