Redundant Power SUpply for SLC 500? Sound weird!
ckchew666
Aug 2003
Malaysia
591
I know this sounds weird, but that's exactly what we are looking for. Redundant Power Supply for SLC 500!
Our scenario is that we have bought SLC 500 for one of our proj, but customer revise their tender spec and they need redundant power supply PLC. I know only PLC-5 & CLX has, but is there any way we can run parallel (1747-P3) to act as redundant power supply?
Does anyone out there tried this before?
Thx. :)
SLC power supplies are meant to run single controller chassis all by themselves. There is no way to use two of them in a redundant configuration.
Even if you were to build a connector to parallel the power inputs, you would have some trouble getting the voltage watchdogs in the CPU to work.
Ken,
Thx for ur info, I never know there is a voltage watchdog in the SLC CPU, until u notice me :p
BTW, what's the function of these watchdog doing there? Mind to explain a bit? Thx.
Hello members, I have a ESD+F&G RIO where the ESD has 1x 1715-A2A with two EtherNet modules + 5x 1715-A3IO with mixed of Analog and Digital IO...
606
I’m using RSLinx to get some of the built in diagnostics items from the PLC. Like @ProcessorName, gets you the name of the program running in...
1,278
Hi guy, Appreciate if you guys can give me some info/manufacturer which has a power supplies with the following spec; Input: 2x 240V AC (one...
2,573
Dear Experts Above mentioned drawing has been taken from one of AB power supplies manuals. In this way we may get 20A redundant 24V dc. But...
3,856
I have a control cabinet that wants to be fed by redundant AC circuits. Is there such a thing as a small, preferably DIN rail mount in-cabinet...
2,229
