Redundant Protocol Should i use For HMI Cimpilcity 9.0.????
sultanahmed
Jul 2013
home
63
Hi All,
I am Using RX3i PAc System G.E, IC695 CRU320 Redundant CPU(Primary & Secondary) with 4 IC695ETM001(Ethernet Module) Modules were used 2 in Primary Station & 2 In Secondary Station, i want to know which Redundant Protocol Should i use For HMI Cimpilcity 9.0.????
PLC Sofware is Proficy Machine Edition 8.5.
Topology is Attached
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
151
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
183
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
326
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
232
I have a L82 system setup redundant that i need to download a lot of programs to in a critical environment. What is the process to do this and...
349
